Power Seat Weirdness
Old Oct 10, 2013 | 09:27 PM
ajnolin's Avatar
Default Power Seat Weirdness
There's surprisingly little wrong with my disco lately (whispering that so it won't overhear). One weird thing that I can't wrap my head around tho.... the driver's side power seat only functions with the driver's door open. What is that all about ?? If anyone could point me to a D1 power seat schematic, it would be most appreciated.
Old Oct 11, 2013 | 07:11 AM
WaltNYC's Avatar
From Rave....
Driver Seat
When the Ignition Switch (X134) is in position I or II,
or the left front door is open, the Left Seat Power
Relay (K113) is energised. Battery voltage is then
applied to the Left Front Seat Control Switch (X152)
through the closed relay contacts and the Driver’s
Underseat Fuse Box (P108). Ground is applied to
the Left Front Seat Control Switch (X152) at all
times. The Left Front Seat Control Switch (X152)
controls 4 seat control motors via 8 switches. When
each switch is moved to operate its corresponding
motor, one seat switch applies ground while the
other applies battery voltage to the respective seat
motor. The motor turns to adjust the seat in the
requested direction.
Old Oct 11, 2013 | 10:37 PM
ajnolin's Avatar
thank you, I haven't been able to find that in the rave. all this time I thought it was messed up... how about that.
CEL came on today, never a dull moment & back in familiar territory once again
Old Oct 14, 2013 | 10:45 AM
WaltNYC's Avatar
That came from the electrical manual, not the workshop manual. They are two separate books/documents.
Old Oct 30, 2013 | 09:29 PM
ajnolin's Avatar
Do you have a link to the electrical manual, and also do you happen to know where K131, Rt. power seat relay, is located ??
Old Oct 31, 2013 | 10:36 AM
WaltNYC's Avatar
this link will take you to the electrical manual.
https://www.cubby.com/pl/LR3+worksho...0Discovery%20I
Old Oct 31, 2013 | 05:23 PM
ajnolin's Avatar
gracias !
Old Dec 21, 2013 | 11:48 AM
locksmith335's Avatar
3rd Gear
My right seat don't work at all. pulled plug and checked for power. have power on 1 big lug hole but I don't know what else to check here. can you help me with any info how to make it at least work once to move it back to the read position.
Old Dec 22, 2013 | 07:06 AM
ajnolin's Avatar
My issue was relay k113. You should check k131 as we'll, as this is the relay for the rt seat. But both seats are fed by k113 when the key is on. Schematic and location is in the thread above
Old Dec 22, 2013 | 07:55 PM
3rd Gear
yep that was problem now I have a working seat again. thank you so much for info.
corbin
Feb 12, 2022 08:32 PM
Grover11
Dec 26, 2014 04:59 AM
tw_salisbury
Mar 10, 2013 06:26 PM
keoni004
Nov 9, 2012 01:10 PM
jfall
Jul 23, 2012 04:32 PM
