Power steering absent at no speed
The “power” steering on my 98 D1 is very heavy at zero speed or very low speed like barely moving in a parking lot (feels like manual steering) but feels fine when moving faster. Am I looking at a new power steering pump here? Anything else to check besides that the fluid is topped up?
Any vehicle with power steering will feel heavy when stopped. In fact, it is not recommended to move the wheels on pavement while standing still in any vehicle... To much stress on the system.
With that being said, the pump is on the weak side and the more RPMs you have going, the stronger the pump will get. Check your fluid level, its probably leaking from the output shaft or your high pressure lines. If you hear any kind of noise while you steer, you could have a pump problem.
Any vehicle with power steering will feel heavy when stopped. In fact, it is not recommended to move the wheels on pavement while standing still in any vehicle... To much stress on the system. With that being said, the pump is on the weak side and the more RPMs you have going, the stronger the pump will get. Check your fluid level, its probably leaking from the output shaft or your high pressure lines. If you hear any kind of noise while you steer, you could have a pump problem.
jycsalas
04-17-2009 02:21 AM
