Power steering absent at no speed
Old Oct 4, 2014 | 02:34 PM
philwarner's Avatar
Default Power steering absent at no speed
The “power” steering on my 98 D1 is very heavy at zero speed or very low speed like barely moving in a parking lot (feels like manual steering) but feels fine when moving faster. Am I looking at a new power steering pump here? Anything else to check besides that the fluid is topped up?
Old Oct 5, 2014 | 08:44 AM
TOM R's Avatar
Think its recommended to go with a Chevy s10 pump
Old Oct 7, 2014 | 06:17 AM
philwarner's Avatar
Thanks for the tip. I've noticed that the lack of power steering seems intermittant: sometimes it works OK when first started and sometimes not. Perhaps an engine RPM thing? Any suggestions?
Old Oct 7, 2014 | 07:35 AM
TOM R's Avatar
Sorry I have not dealt with it yet, just going by threads I had read, probly try the search
Old Oct 7, 2014 | 10:00 AM
DiscoBlanco's Avatar
Any vehicle with power steering will feel heavy when stopped. In fact, it is not recommended to move the wheels on pavement while standing still in any vehicle... To much stress on the system.
With that being said, the pump is on the weak side and the more RPMs you have going, the stronger the pump will get. Check your fluid level, its probably leaking from the output shaft or your high pressure lines. If you hear any kind of noise while you steer, you could have a pump problem.
Old Oct 8, 2014 | 01:22 PM
philwarner's Avatar
Originally Posted by DiscoBlanco
Any vehicle with power steering will feel heavy when stopped. In fact, it is not recommended to move the wheels on pavement while standing still in any vehicle... To much stress on the system. With that being said, the pump is on the weak side and the more RPMs you have going, the stronger the pump will get. Check your fluid level, its probably leaking from the output shaft or your high pressure lines. If you hear any kind of noise while you steer, you could have a pump problem.
No noises that I've heard even at lock, but the PS fluid was near the bottom of the reservoir so I topped it up again - it must be contributing to the under carriage lube system along with the valve covers. It is not marking its spot quite as much since I tightened the valve cover bolts to spec, but I still get that wonderful British hot oil aroma so valve cover gaskets are in its future. I'll keep an eye on the PS fluid level and look for a leak - it was turning OK this morning when barely moving, but I was on gravel.
orionpaxx
Nov 7, 2011 10:07 PM
eandrews2
Feb 28, 2011 06:35 AM
MountainOx
Off Topic
Dec 16, 2010 07:37 AM
jycsalas
Apr 17, 2009 02:21 AM
soupdogg
Sep 25, 2007 12:49 PM
