Proline Propshaft
Old Sep 13, 2012 | 04:40 PM
MrFister's Avatar
Default Proline Propshaft
Has anyone Used this Proline Kit to eliminate the Flex coupler. I Have just started getting into some actual rock crawling stuff and with the money I've spent on Flex Couplers I could have bought this.
The other option is a Double cardan. I've got a 2" lift would this be too much over kill or well worth it.
Here's a pic. I'll post more. Wheeling Chinaman Gultch loop in Buena Vista Co
Thanks guys
Old Sep 13, 2012 | 04:46 PM
CUpgt's Avatar
You can also get a u-joint shaft from a 98 disco or I believe some RRC. Either way ditching the rotoflex is the way to go imo.
Old Sep 13, 2012 | 05:56 PM
Bkreutz's Avatar
I've had hit and miss luck with Proline (the one I'm thinking of is Rovers North "other" line) some of it is ok and then some others are junk. Yes you can use an older Disco driveshaft, or have one made (probably a better idea if offroad it). then the only thing to do is change the diff input flange so you have something to bolt the new shaft to. Maybe you can find an input flange at a junkyard from an early D1. beautiful trails around your area. I have a friend that lives near Nathrop that I have visited and done some trail rides (in flat fender Jeeps, but don't hold that against me)
Old Sep 13, 2012 | 09:01 PM
MrFister's Avatar
Yeah getting rid of the roto is the only way to go if your doing any off road. I couldn't believe how fast you can shred thoes things. I really think I should do the double cardan because ya never know what you may change later.
Thanks about the trails. I really want to hit up kelly flats trail before the snow flies but have some little repairs to do first.
Old Sep 13, 2012 | 10:36 PM
fishEH's Avatar
Someone should have a genuine shaft you can rebuild along with the four bolt flange.
Jake has one for sale now I think on Dweb.
Why would a Double Cardan be the other option? DC shafts are for the front, not the rear. I have a 3" lift and still run the stock ujoint driveshaft in the rear.
Old Sep 14, 2012 | 04:39 AM
Jake1996D1's Avatar
Let me know if you need one I have everything except the pinion washer. $140 shipped?
Old Sep 14, 2012 | 06:11 AM
antichrist's Avatar
DC is the correct propshaft for some diff pinion/transfer case relative geometries.
If there's a small vertical angle difference you want single cardan, for a DC you want your pinion pointing at the transfer output.
Old Sep 14, 2012 | 10:43 PM
MrFister's Avatar
Thanks for clearing that up Anti. I guess my thinking was if two u joints is better than one than 3 is better than 2.
Kinda the bigger the hammer the more you can fix. J/k
98JPRDISCO
May 2, 2010 11:17 PM
98JPRDISCO
May 2, 2010 11:15 PM
targotsi
Feb 18, 2009 06:22 PM
discoxd
Oct 20, 2008 10:51 AM
brooksa
Mar 4, 2008 09:44 AM
