Proper replacement fuel pump
Old 04-23-2011, 11:09 PM
jasonrusso's Avatar
Sorry guys, pc all the way. I like to be able to do things my way.
  #22
Old 04-24-2011, 07:09 AM
antichrist's Avatar
Use fuel injection clamps, not the worm drive hose clamps that come in the kit.
  #23
Old 04-24-2011, 08:24 PM
jasonrusso's Avatar
What are fuel injection clamps? Squeeze clamps?
These are the kind I use at work: https://www.belmetric.com/chp80-p-91...2&cPath=15_142
  #24
Old 04-25-2011, 06:42 AM
antichrist's Avatar
Not what I meant, but they will certainly work.
Fuel injection hose clamps are meant for higher pressure hose.
  #25
Old 04-25-2011, 12:25 PM
DiscoJag's Avatar
Wink Fuel Pump Replacement
Hi guys. I just did this last weekend, so I thought I would chime in. I bought the Airtex E3270 pump from Advance Auto for about $85. It's for a '96 Chevy Impala SS V8. It's supposed to be guarunteed for life, but I guess that's if you put it in a Chevy. You get the pump only. I pulled the assembly out of the tank (not a bad job, except for rusty screws), and disassembled it carefully and put the new pump in place of the old one. It's not that bad, you just need to be careful to get the strainer sock off the old and on the new pump. The electrical plug is exactly the same. The fuel line that goes from the pump nipple to the inside of the exit pipe has to be high pressure - the old one is put in with single use clamps, so you have to cut that off. The clamps need to be fuel injectin clamps. I grabbed some fuel line I had in the garage and used it and it almost immediately popped and I had pull it back out to replace it with good stuff - rated to 130 PSI. I did the filter too. The filter was probably the cause of the whole mess and the ironic thing is I've had the filter sitting in the garage for a couple of years. I could not blow through the old filter. New one, no problem. Of course rust on a 15 year-old truck is going to be rough. This was the original fuel filter, I'm sure. I soaked the joints with PB Blaster and eventually broke both ends loose - be careful - there are little o-rings on the filter "nipples". I lost one and fortunately, stopped trying to fix the leak by tightening the connections before I ruined anything and took the new filter back out and realized my mistake. The filter will leak without good o-rings. I never thought my fuel filter would be clogged, I always put quality premium fuel in the truck. It would have saved me a long tow if I had changed that fuel filter a while ago. Hope this helps !
  #26
Old 04-25-2011, 05:13 PM
I went with the Pro-Line drop in plug and play from Rovers North, great unit at a great price.
  #27
Old 05-29-2011, 10:34 PM
jasonrusso's Avatar
Well, I changed the fuel pump and filter about 3 weeks ago. The results have been odd. Sometimes I still have the extended crank, sometimes I don't. I let it sit for a week while I was in Germany and it fired right up. Today, I went into the store for a couple minutes and I had the extended crank 7-10 seconds. Any ideas?
  #28
Old 06-13-2011, 09:52 AM
DiscoTechCO's Avatar
4th Gear
Hi guys- I wanted to second this post- I just did my fuel pump with the E3270 from advance auto too. Just remember to buy an extra foot of fuel line (they only give you about 2" with the pump). And +1 on the high pressure hose clamps. Everything comes apart easily and clips right back in. I stuffed the aftermarket sock filter they sold me into the OE assembly because the original sock was pretty beat up.
And to think the cheapest drop in fuel pump is $300. $630 from the dealer.
I was able to do a fuel pump and filter for under $100.
  #29
Old 06-13-2011, 09:56 AM
4th Gear
This was on a 1997 Discovery SD V8i.
  #30
Old 06-13-2011, 02:17 PM
RN has the Pre-ael drop in plug and play for early 97 and below for rightr at 100 bucks, that is what I used. The AEL version is more but still less than the prices mentioned here.
MarvelVT
10-23-2019 08:09 AM
Travelor
09-24-2015 06:11 PM
JumPeR04
04-07-2011 09:52 PM
03RRDude
10-26-2009 07:18 PM
robdis96
08-05-2009 05:59 PM
Quick Reply: Proper replacement fuel pump
