Pulling Apart a Rocker
Old Apr 2, 2022 | 09:51 PM
DiscoNewbe's Avatar
Default Pulling Apart a Rocker
Hey all,
trying to pull apart a rocker arm setup apart to install new, steel rockers. The first, old rocker arm came right off, but then I got to the first pedestal… and it’s not budging… is there a shim or something that I’m missing here? Should i just pry-away?
Thanks!
Old Apr 2, 2022 | 10:19 PM
XCELLER8's Avatar
the shaft is likely deformed a little where the pedestals/bolts were......just be careful and try to tap it off, might help to twist as you tap, you could also try heating the pedestal a little
Old Apr 3, 2022 | 11:02 AM
DiscoNewbe's Avatar
yes, can confirm, just needed some hammering. Thanks.
JohnZo's Avatar
Maybe some penetrating oil or gasoline will help break the varnish. It will just slide on after you clean it up and put it back together.
Dukaroo
Jun 28, 2021 12:14 AM
matt3502
Mar 27, 2021 04:19 PM
earlyrover
Nov 23, 2019 03:33 PM
RoverSeriesInf
Apr 25, 2017 10:01 PM
XCELLER8
Sep 19, 2009 03:27 PM
