Question about bad U-joint and transfercase/trans mounts
Ever driven a manual transmission vehicle with a bad motor mount or trans mount? it clunks every where when put into gear and such. My Disco does that but I don't see any perished mounts that are obvious. I only see 2 mounts on the T-case and none on the trans. Am I Missing something? What else could it be? If someone local wants to test drive it and tell me what they think I'd be appreciative.
Also, my Ujoint at the rear diff is perished. But I also have a high pitched metallic noise when driving, if I let off the gas or put it in neutral it goes away. Coming from U-Joint? And when I let off the gas or put it in neutral there is a sorta loud metallic noise. Best described as dragging a chain or heatshield for a split second. U-joint as well?
Thanks guys!
Thanks guys!
If it were me I would just replace all the uj's and start servicing them on the correct intervals that way there is no question. It is cheap and easy to do (well getting them out is sometimes a pain) and is good insurance. I did all mine when I bought mine along with my 60k service. Just my 2 cents. Good luck.
