A quick question about valve cover gasket replacement.
Old Jul 2, 2011 | 01:00 PM
EkaInfinitos's Avatar
Default A quick question about valve cover gasket replacement.
The RAVE says to use an impact adhesive (RAVE mentions "Bostick 1775 or equivalent") on the valve cover seal face and corresponding face of the gasket. Is Hylomar an acceptable equivalent? Is the stuff really necessary at all?
Thanks.
Old Jul 2, 2011 | 01:26 PM
Before you replace them tighten the bolts that hold them on, they work loose and then they leak.
It is a good idea to snug them up at every oil change.
Old Jul 2, 2011 | 01:33 PM
I'm actually on the tail end of installing a rebuilt engine in my spare time; I pulled and cleaned the covers from the previous block and will be installing them shortly...if I don't need an adhesive/sealant.
Old Jul 2, 2011 | 03:12 PM
XCELLER8's Avatar
Cool
the new gaskets dont need any sealant to work, the sealant is to keep the gasket "glued" to the cover while you position it . A word of caution...as you manipulate the covers into place, make sure the 4 round bushings in the gasket ....STAY in the gasket, not drop into the valvetrain and out of sight down into the motor......another reason to apply a little sealant !
Old Jul 2, 2011 | 04:32 PM
That's exactly what I was wondering about. I will play with it a bit and if I don't feel comfortable without the goop, I'll get some.
Thanks for your quick replies, guys.
Old Jul 3, 2011 | 09:09 AM
Don't install used gaskets, most likely that will also leak and you will then have to repeat the replacement. Once fixed, make sure to tighten the bolts at every oil change.
sayeedA
Jun 3, 2024 01:39 PM
robert.juric
May 8, 2015 03:39 PM
humroot
Nov 4, 2007 12:05 PM
jwfuller
Jul 22, 2007 08:07 AM
