R380
Old Sep 10, 2024 | 10:24 PM
Zanz's Avatar
Mine is manual,
I don’t know about the auto.
Old Sep 11, 2024 | 07:35 AM
WaltNYC's Avatar
Originally Posted by Zanz
You mean there are aftermarket panels for the D 1 available ?
I don’t need at the moment but it’s good to know about the availability from whom.
https://www.sp-4x4.com/
https://froggatts.co.uk/parts-catego...overy-1-parts/
https://yrmit.co.uk/vehicle/discovery-1/
Old Feb 14, 2025 | 11:56 PM
Zanz's Avatar
Good morning,
to let you know about the outcome of the t-case lt230 and gearbox r380 modifications as we discussed some time ago.
Finally, the rebuild is done,
Sleeved the t-case and upgraded to 1.410 gear set and (ftc5042 & ftc4977 Ashcroft ) 5th gear high on the gearbox, and obviously changed a lot of other parts.
Car feels great in driving,
went steep uphill on 4th gear when usually used to drop to 2nd gear, feels much better even accelerates immediately.
Regarding the 5th high gear, it’s great when you have long roads, speed goes much higher and quickly.
A small issue, they are leaking a negligible small oil drops. Something which will be discussed with the mechanic,
Are discos possible to stop all oil leakages ?!!
Old Feb 18, 2025 | 02:02 PM
WaltNYC's Avatar
If it ain't leaking it is empty
Old Aug 31, 2025 | 02:27 AM
Zanz's Avatar
Default Lt230
Hello everyone,
as discussed some time ago in this thread regarding reconditioning of both gearboxes, I loved the message that if it ain’t leaking it’s empty !!
My lt230 is leaking again, possibli from the intermediate shaft, so I’m thinking of replacing it with Ashcroft HD 300M. My concern is the o ring on the intermediate shaft. Does any, more robust ones are available ? Maybe replacing the ordinary rubber ones ?
As usual,
any help would be greatly appreciated.
OffroadFrance
Sep 6, 2018 09:58 AM
pitpaplo
Oct 31, 2014 05:41 AM
Hercu
Nov 18, 2012 08:12 AM
sailorcolin
Feb 21, 2008 05:08 PM
Smokeyone
Jun 4, 2005 03:11 AM
