Sponsored by: CARiD
T 230 T Transfer case Disco 1 TDi manual
Old Nov 18, 2012 | 08:12 AM
Hercu's Avatar
Default T 230 T Transfer case Disco 1 TDi manual
After weekend camping and heavy 4x4 I heard a awful clank when turning sharp left.
Going threw the whole routine back home,stripping and inspecting left hub, right hub and later front diff without finding anything wrong.
Drained the oil from transfer case and found steel shavings and decided to drop Gearbox and transfer. This is not a 1 hour job !!!!
Opened the 3rd diff in the T/case to find both shafts holding the planetary gears broken and gears seized onto the shaft pieces still in tact.
My question: Why did the gears seize onto the shafts? (The case was full with oil).
I have received the new Shafts and planetary gears but old planetary is 8 toothed and new is 9 toothed. Will this be a problem.
I am replacing the sun gears as well.
Any tips and suggestions will be highly appreciated.
Discovery 1 TDi (300i engine)
Manual 5 speed R 380 gearbox
T 230 T transfer case
3" lift with Rotoflex rubber coupler replaced with U-Joint.
Hercu
Attached Thumbnails T 230 T Transfer case Disco 1 TDi manual-transfer-gears-broken.jpg
OffroadFrance
Aug 19, 2014 09:00 AM
Hercu
Oct 22, 2013 04:54 AM
NiteTrain
Apr 26, 2012 02:14 PM
Josh darl
Defender
Sep 29, 2010 06:22 PM
