R380 needs 2nd gear for 95 D1
Old Jun 27, 2018 | 07:26 PM
mirrajumper's Avatar
Default R380 needs 2nd gear for 95 D1
hi guys. I’m looking at buying a 95 D1 that will need a new 2nd gear in the near future. Ashcroft reviews have been 50/50 lately- is there another option?
What is a “ do it right” budget for this R380 overhaul?
Thanks.
Old Jun 28, 2018 | 08:44 AM
fishEH's Avatar
Check out Synchro Gearboxes.
Old Jun 28, 2018 | 09:23 AM
Thanks. Will check them out.
Old Aug 6, 2018 | 12:31 AM
Ankeneering's Avatar
second gear sychros on r380s are famous for failing.
Old Aug 6, 2018 | 06:16 AM
Toran's Avatar
For the time being I have learned not to use 2nd gear unless I am already at a complete stop.
Old Aug 10, 2018 | 11:24 AM
Yea, second always failing confuses me as it seems like a useless redundant gear. I couldnt imagine it being used enough to actually fail. Even before I figured out it was a weak link I always went one to three... just because including it in the effort to get to highway speed was a waste of energy. But yea, from a complete stop its sometimes a reasonable option.
Old Aug 10, 2018 | 12:57 PM
DavC's Avatar
Thanks.
I had an ashcroft R380 to me for about $2k, standard gear setup, non HD add
unfortunately had a transfer box go out right before the swap so had to get one and get that fitted.
Along with a new clutch, fork, etc those pieces, the "new" transfer box (and put an ashcroft drilled input gear), new prop shaft u joints, flywheel machining, rear main seal done and a few other bits, it was probably around $5k more to have everything done.
If I was just doing trans only, maybe budget $3k for the install? I had a weird situation where a bunch of things needed doing at the same time.
BierNut
Sep 11, 2019 03:13 AM
mirrajumper
Jun 27, 2018 07:29 PM
kb24
Mar 8, 2016 08:31 PM
ArmyRover
ROAMING WITH FRIENDS
Jan 29, 2013 07:33 PM
rumpig70
Nov 15, 2007 03:22 AM
