Radiator (help)
logan_gibson (10-28-2020)
All metal wouldn't be that bad.
Still cheaper to have the OEM gone through if you have a reputable shop nearby.
I think it cost me somewhere in the 100-150 range.
I replaced my radiator 1.5 years ago with the Nissens from RockAuto. It's aluminum with the plastic tanks, but it's been through multiple zero or sub-zero degree temps in that time and I've had no issues.
In Denver I had 2 shops quote $450+ to redo the stock radiator, so I went the Nissens route.
Atlantic British used to sell an all metal unit for like 600.00. The plastic tank/aluminum units aren't bad, but they aren't anything like their OEM cousins!
But whatever you do DO NOT get a Chinese Aluminum Radiator from Ebay or any other place. Only stick with Allisport stuff!!! I nearly just killed my 4spd Auto due to the cheap POS Chinese Radiator failing on it's first road trip. Things worked out and I was back on the road in 3hr with a replacement radiator, and lower transmission line, but it could have really really really have been bad.
JohnZo (12-10-2022)
