Radiator in a Standard
Well now that you know the cooler is there, next time at the pick-N-pull grab another cooler and double up.
More is always better!!
RE: Using a Nissen's 64029 with the AT Cooler in a MT truck.
I remember a guy with a '95 DI a few years back used the "extra" internal cooler to create a PS Fluid Cooler.
Overkill, but still an interesting idea.
It was slick and didn't take much more than a few fittings/hoses.
If I can find the pic I'll post it.
Have a good look at the metal pipe sections on the lines because they like to RUST!
Once the metal gets rusty the line tends to split and leak.
I've learned that lesson the hard way once or twice so now if the lines look funky I just replace them early.
Toran, you asked about painting/coating a replacement radiator, when I replace new cooler lines I always give them a coat of paint. This has helped keep the lines from rusting and makes them last way longer.
Mine arrived last week.
I dont trust those plastic caps, so took the radiator into the hardware store and picked up these pipe caps. The radiator has pipe threads. I dont recall the size so take it with you.
I also put some locktite on the threads for good measure.
