Radio connection issues
Old May 17, 2014 | 10:24 PM
abran's Avatar
Default Radio connection issues
Took apart my center console to replace my AC switch that went out, in the process I had to remove my stereo.
Kind of just starting unplugging things.
Sub and Main, Are those amp outputs or antenna inputs? Is the larger cable in the middle of the head unit for CD player?
Its weird because there are definitely 2 antenna cables in the back, but only on that goes through a connector that matches the SUB or MAIN. And that connections has come loose/pulled apart.
Thanks.
Old May 19, 2014 | 02:06 PM
WaltNYC's Avatar
yes, and yes. sub/main for antennas and the black wire hanging from the back connects to the CD player.
Old May 19, 2014 | 02:09 PM
abran's Avatar
Thank you. Now my problem is that the antennae adaptor from the straight pin with outer connections to the 90 angle one that goes into the radio is broken. Anybody know a good source? I have checked 3 auto parts stores so far.
dogstarsix75
Apr 24, 2020 01:33 PM
thegoat
Audio/Visual Electronics
Apr 9, 2014 01:26 AM
thegreekmason
Jan 8, 2013 02:13 PM
ZB-30
Jan 2, 2013 08:30 PM
Paul Grant
Feb 4, 2012 08:29 PM
