radio help! please!
If you don't know the code try looking in the glove box, the owners manual, under the hood somewhere (usually written near the radiator). those are common places where they write the code down.
On a side note if you put in the wrong code more than a couple times it will lock you out from entering any more codes and you will have to keep the radio powered for an hour or so (untouched) before you can try again.
Yeah, just give them the full VIN, and they will give you the radio code. I had already put the code in wrong a time or ten. So I had to leave the ignition on for an hour, then enter the correct code in, and it works!
RideMTB
Audio/Visual Electronics
May 10, 2013 10:32 PM
whurst79
Jan 28, 2013 09:24 PM
