Random D1 and Offroad stuff so I stop thread-jacking
Old Apr 27, 2012 | 04:36 PM
Jake1996D1's Avatar
Originally Posted by wheelgarage
Was her last name Kate by any chance....
Don't worry about the MED springs handling a little extra weight. From the TF guide, TF018's can handle a winch and a bumper (up to 220lbs add'l weight).
Curious to see the lift height on yours....have fun.
You got your wheels yet?
Old Apr 27, 2012 | 05:05 PM
wheelgarage's Avatar
Nope...Justin said Monday or Tuesday they will get them in....torture.....
Old Apr 27, 2012 | 05:17 PM
Jake1996D1's Avatar
Pictures!!!
Old Apr 27, 2012 | 06:40 PM
Will do....once I get them......
Old Apr 27, 2012 | 09:57 PM
shaggy52282's Avatar
Well...the first hour or two (all I had time for tonight) of installing the lift is neither going as well as I had hoped nor as bad as I feared. Hopefully tomorrow goes a bit better.
Old Apr 28, 2012 | 09:42 AM
priceg's Avatar
I love my TreadWright tires. I currently am running Gaurddogs on my p38, Pumas on one of my D1s, Warden ATs on my Montero, and Crawler MTs on my Jeep. You can not beat their products for the money, period.
Old Apr 28, 2012 | 01:26 PM
CUpgt's Avatar
I have ran pumas and now wardens. Absolutely no complaints!
Old Apr 28, 2012 | 01:36 PM
ValveCoverGasket's Avatar
Originally Posted by shaggy52282
Is there a functional purpose for that suggestion? I don't have any leaks...that I have found at least.
so you can paint the roof properly...
and the roof rails probably need resealing anyway!
Old Apr 29, 2012 | 06:56 PM
Well...lift is installed. I am happy to say that the front went much more smoothly than the rear (installed the front shocks/springs, bled the brakes and flushed the PS fluid in less time that just the rear shocks/springs)...although the only real complication on the rear was having to re-cut the threads on the upper shock mounts with a die which wasted a lot of time. I will post the before and after pictures later. I also have my 235/85/r16 Treadwright Crawlers coming Tuesday, so hope to have them mounted on Wednesday most likely.
I did have one question on the front shocks. It seems like the threads are "too long". If I crank down the top and bottom nut to tight (I am pretty thin, so tight for me is very rarely over-tight) the "bolt" part of the shock makes contact on both the top and bottom (bottom is the axle and top is various hoses). Is that normal? Since they are nylock nuts do I just back them off a little to allow for more clearance?
Edit: and if I do back them off a bit, won't the bushings eventually wear and allow it to make contact anyway?
Old Apr 29, 2012 | 07:33 PM
Jake1996D1's Avatar
Sorry dude you lost me - you have a pic of what you're talking about?
