Random D1 and Offroad stuff so I stop thread-jacking
Old Apr 30, 2012 | 11:17 AM
  #31
dougwashere's Avatar
6th Gear
So after doing some research on some torque specs. We may have over-tightened the shocks. Some manufacturers recommend around 40 Nm (30 ft-lbs) on that nut. It looks like Land Rover recommends only 37 Nm on the stock bottom mount (shock to front axle). However, the Terrafirma shock bolt is a larger diameter so it can take a little more torque.
Based on my perfectly calibrated arm strength and "grunt torque" estimates we have more than 40 Nm on your nuts. We should fix that this evening.
Old Apr 30, 2012 | 11:40 AM
  #32
fishEH's Avatar
I think the torque spec has more to do with properly compressing the bushings rather than how large the pin diameter is.
Old Apr 30, 2012 | 11:44 AM
  #33
6th Gear
That would make sense since it is an unusually low amount of torque based on the bolt and nut size.
Which must be why they are using nylock nuts... I can see clearly now the rain is gone.
Old Apr 30, 2012 | 11:50 AM
  #34
shaggy52282's Avatar
I am not sure I am comfortable with people discussing my nuts on a public forum.
BTW, there seems to be a lot of discussion about removing the headliner (for maintenance) and some people leaving it off, but I am having trouble finding any pictures of what it looks like with no headliner. I am not a fan of removing the headliner because it seems like it would be a pain to get it back on...but if it looks good (...eye of the beholder) without it that might be an option.
Old Apr 30, 2012 | 11:52 AM
  #35
Jake1996D1's Avatar
Yes! Rule of thumb.. if the bushing is not sleeved then tighten it until it starts to buldge a little bit. I use loc-tite on them too just in case.. The arms on my 3-link are like this most radius arms so I threw on some red lock-tite and called it good.
Old Apr 30, 2012 | 11:53 AM
  #36
tweakrover's Avatar
I had the same issue with the front shocks, I think I just backed it off enough that the shock was just barely clearing the axle
Old Apr 30, 2012 | 11:56 AM
  #37
fishEH's Avatar
I've had my headliner out for over a year now. I meant to recover it but haven't gotten around to it, LOL. Taking it out and putting it in is easy. Its one big piece that comes out through the cargo door. I'll see if I can snag a pic.
Old Apr 30, 2012 | 12:09 PM
  #38
pinkytoe69's Avatar
I can also vouch for the fact that it is really easy.
The hard part is finessing it out the back door without spilling the remnant nuggets from the rodent civilization that was living on top of it.
Old Apr 30, 2012 | 12:12 PM
  #39
fishEH's Avatar
Sans headliner.
Old Apr 30, 2012 | 12:22 PM
  #40
Hmm...I guess I didn't think to account for all the wires and such.
I have never been good at working with fabric...or really anything other than computers...so even if it is "easy" for a normal person...it very well could frustrate the heck out of me.
