Random stalling (almost)
so every now and then I will be a a stop light or stop sign and my truck will be idling perfectly. Then when I press the accelerator to go it will choke out and almost stall out. It will do this a couple of time then run fine for weeks, and then it will do it again. Any ideas?
Start with removing the IAC Valve (Stepper Motor) and cleaning the Pintle Tip, and also the female cup end where it seats with some throttle body cleaner. Go easy removing the valve so you don't kill the gasket, and/or have a gasket (ERR3359) on hand ready to go.
If the IACV is old most likely it's time to replace it, but clean it first and see if things improve.
It also might simply be that the IACV is dying. Happened to me.
https://landroverforums.com/forum/di...pensive-81775/
