Random stalling (almost)
Old Jul 29, 2018 | 07:12 PM
aemnky606's Avatar
Default Random stalling (almost)
so every now and then I will be a a stop light or stop sign and my truck will be idling perfectly. Then when I press the accelerator to go it will choke out and almost stall out. It will do this a couple of time then run fine for weeks, and then it will do it again. Any ideas?
Old Jul 30, 2018 | 07:12 AM
WaltNYC's Avatar
Things I'd check first... IACV, fuel filter, air filter. Those are the easiest and cheapest. Plugs and wires are always a good thing to keep up with as well. If those relatively easy things don't solve the issue I'd dig deeper.
Old Jul 30, 2018 | 09:13 AM
OverRover's Avatar
Start with removing the IAC Valve (Stepper Motor) and cleaning the Pintle Tip, and also the female cup end where it seats with some throttle body cleaner. Go easy removing the valve so you don't kill the gasket, and/or have a gasket (ERR3359) on hand ready to go.
If the IACV is old most likely it's time to replace it, but clean it first and see if things improve.
Old Jul 30, 2018 | 06:03 PM
aemnky606's Avatar
I did a complete engine rebuild about 3000 miles ago. At that time I replaced all plugs, wires, coil pack, air filter, injectors and fuel filter. Every thing on the intake/ plenum was taken apart and cleaned. I will check the stepper valve for any build up.
Old Jul 30, 2018 | 09:38 PM
XCELLER8's Avatar
if everything mentioned above checks out, I would suggest you go back in and check the intake manifold bolts, if they are slightly loose , that may be a source of a vac leak.....speaking from experience
Old Jul 31, 2018 | 10:29 AM
WaltNYC's Avatar
It also might simply be that the IACV is dying. Happened to me.
https://landroverforums.com/forum/di...pensive-81775/
Old Aug 2, 2018 | 07:57 PM
aemnky606's Avatar
Well I did a smoke test and did not find any leaks in the system. I have recived my new IAC valve and a new gasket. The new valve came with an o-ring should I be using that too, or just the gasket?
Old Aug 2, 2018 | 08:59 PM
Icannap1's Avatar
Don't use the O-ring. the tabs will eventually bend as the valve base does not sit flat on the throttle body. Use the flat gasket and it will last.
Old Aug 3, 2018 | 12:06 AM
robertf's Avatar
Is the AC on when it stalls and does it run perfect when AC is off?
mine is doing this. I noticed voltage dips into the 12s when its ready to stall so Im suspecting a condenser fan on its way out
Old Aug 3, 2018 | 08:23 AM
aemnky606's Avatar
No I very rarely use my ac. My voltage will drop a little due to the very low idle/ stall condition because the alternator is below the required rpm's.
