Read this if you have a High Idle
Old Jul 5, 2010 | 06:38 AM
  #31
tweakrover's Avatar
Mine is, I have an unhealthy infatuation with british vehicles. Its an 07 triumph thruxton.
Old Oct 5, 2010 | 09:59 AM
  #32
jordamf's Avatar
I am so doing this. How ever question, I remember reading somewhere that you have to replace the alarm ecu with the ecm at the same time from the same vehicle. Something like they are linked with codes some how.
Old Oct 5, 2010 | 10:48 AM
  #33
Chris-bob's Avatar
Default Why isn't this a sticky?
or at least a cleaned up version made into a sticky. I just realized I never found it when I searched because the search was only looking at the last two weeks. Silly me.
So if I have to replace a component that requires the ECM to be reset, what affordable program is out there that I can purchase. I cannot go to a Stealership(well, I could, but it would cost me $1300 in travel costs alone).
Old Oct 5, 2010 | 07:18 PM
  #34
Spencerfitch's Avatar
the tool would cost alot.
Old Oct 5, 2010 | 09:41 PM
  #35
jordamf's Avatar
Well Spencer fish it was your post about pulling the ecu and then later pulling the alarm ecu to make it start that brought your idle back to normal. So never mind i answered by own question.
Old Oct 5, 2010 | 11:25 PM
  #36
geek_IM's Avatar
Originally Posted by Spencerfitch
I may have figured out how to reset the ecu for free!!
AHHH!!!!!!
Can you paraphrase for all us slower folk exactly how you accomplished this?
Old Oct 6, 2010 | 02:13 PM
  #37
discomedic4's Avatar
You can't. He thought he did but it didn't work out. Testbook or Autologic are the only way to get it done. Testbook is the dealer software so I prefer it. But that's just me.
Old Oct 6, 2010 | 05:07 PM
  #38
He is correct. Im no guru. Only play with stuff untill I figure something out.
Old Oct 6, 2010 | 08:41 PM
  #39
Spence I was just stating what I thought I remembered. You didn't find a way to reset the ECU that I am unaware of did you? You finally resolved your issue with the proper mating of the new ECU and Alarm Module correct? I just want to clarify in case i was wrong.
Old Oct 6, 2010 | 09:38 PM
  #40
Thats right. But pulling the big black wiring harness from the ecu with the key turned on and plugging it back in caused the truck to idle about normal. But then it would work its way back up eventually MAYBE my ECU was bad?
