Rear AC
Old Feb 5, 2019 | 05:20 PM
RBSDISCO's Avatar
Default Rear AC
Is there anywhere for information on removal of a rear AC system with headliner or install of the same? I started removing it from my other D1 and there is a lot to it.
Old Feb 12, 2019 | 05:19 PM
Socal88's Avatar
Are you removing the AC unit all together or just the duct wok in the headliner? I removed the duct work from the headliner and just ported the air with a piece of 4" aluminum flex pipe out the speaker hole then installed a 4" RV adjustable vent on the back pillar, blows all the way to the front windshield. Works great for the dogs!
Old Feb 12, 2019 | 08:06 PM
Icannap1's Avatar
You will need to remove the wiring harness to set the fan speed and to turn on the A/C, remove the A/C system and lines, and as for the vents you already have that part figured out. You could look at the Rave manual and just split the harness from the donor truck and just remove the wiring circuit that is needed and route that to their required locations oh you will also have to route power for the A/C circuit to the fuse box out by the battery if you want it factory but if you just want to rig it run power to the back as if you were installing a car amp power kit fused, run at least 4 extra wires from front to back, one for on fused, i believe its two for the fan speed need to look at the Rave manual but it's doable either way.
Old Feb 13, 2019 | 12:01 PM
RBSDISCO's Avatar
I am trying to move the whole unit, learin a lot as I take each piece down.
Llamasayswhat
Jul 11, 2019 08:43 PM
Llamasayswhat
Jun 21, 2019 01:20 PM
memphis_rover
Nov 29, 2017 11:59 AM
Sixpack577
Jul 23, 2017 03:36 PM
machinetech
Aug 2, 2016 07:31 PM
