Rear Brake Rotor Grind noise:-(
Hello Good People,
I have some noise coming from the passenger rear brake rotor. The sound is low but more obvious when coming to slow stops.
What should I be looking for when I take the wheel off?
With the tire rim still on I can rub my finger across the outer side of the rotor and it is smooth, while the inner side has some grooves. I notice the outer side of that tire rim being slightly more dirty if that makes a difference.
Thank you!
Thank you!
