Starter Grind.
Old Jul 6, 2010 | 11:23 PM
rhino_e28's Avatar
Default Starter Grind.
I went wheeling this weekend and went through the mud pit a few times. (Got stuck each time after encountering about 3 and half feet deep of mud) Now my starter grinds after it starts each time. What can I do to fix this?
Old Jul 7, 2010 | 12:10 AM
Long Haul's Avatar
I would pull the inspection cover off the bottom of the bellhousing and see if you got some mud around the flywheel. If there is just take a garden hose and spray all the junk out at least thats what happened to me. If its clean and dry it might be something stuck in the starter
Old Jul 7, 2010 | 12:13 AM
Long Haul's Avatar
Also dont forget to check your oil in your axles and check your wheel bearings and swivel ***** for water/mud in them.
Old Jul 7, 2010 | 07:38 PM
Do like Long Haul said and if it continues check and make sure you did nto knock the starter loose/out of alignment.
Keecho
Jun 2, 2012 10:52 PM
timothybryder
Apr 14, 2009 05:12 AM
98discoIN
Apr 7, 2009 10:07 AM
FALLFORWARD
Feb 18, 2009 08:52 AM
sdsilvere38
Sep 1, 2008 12:08 PM
