Rear bulb failure
Old Jan 1, 2011 | 10:37 AM
Ronin's Avatar
4th Gear
Default Rear bulb failure
How do I replace the rear brake light bulb on a 1999 land rover discovery?
Old Jan 1, 2011 | 10:40 AM
Well since there are 2 brake light bulbs on each side we kinda need to know which one it is.
Old Jan 1, 2011 | 11:06 AM
Just remove the lenses and replace any bulb in sets so they stay at the same brightness, also replace any that are getting black just prior to failing.
Old Jan 1, 2011 | 11:07 AM
Ronin's Avatar
4th Gear
Default Sorry
Passenger side. Sorry...
Old Jan 1, 2011 | 11:49 AM
kenk's Avatar
Well, if you have rear jump seats, you have to be a contortionist to get the lenses out. There is an access panel inside, that you reach into and take off two wing nuts or plastic nuts(can't remember). Then the whole lens housings comes off. There is a white plastic piece that holds each bulb. It twists 1/8 turn or so and pops off.
It was a big enough pain getting the lens out I replaced all the bulbs while it was out.
Old Jan 1, 2011 | 02:33 PM
There are bulbs in the rear quarter panel as well as the rear bumper.
How to change the bulbs depends on where the bulb is.
Old Jan 1, 2011 | 04:47 PM
Ronin's Avatar
4th Gear
Thanks all :-)
Old Feb 11, 2011 | 01:50 PM
teamfalcon's Avatar
I'm assuming it's the same for an 08 LR3.....any tips? My bulb went out....
Old Feb 11, 2011 | 02:12 PM
Chris-bob's Avatar
Not sure. Might want to try the LR3 forum. Most of us only have D1s
Wayne
Oct 2, 2020 12:10 PM
Classklown90
Aug 21, 2010 07:24 PM
Madison Francis
Apr 19, 2009 12:39 PM
m1cajah
Apr 14, 2008 06:43 PM
artcareer
Aug 20, 2006 05:23 PM
