Rear Drivers Side Sagging
Old May 8, 2016 | 10:10 AM
jpluncford21's Avatar
Default Rear Drivers Side Sagging
I'm running 2" TF Big Bore Expedition shocks and the rear end on my drivers side is sagging quite a bit. Is this an indication of a blown rear shock? I'm about to order a new one. How hard of a job is it to remove and install?
Old May 8, 2016 | 10:39 AM
AK Rover's Avatar
I would suspect that your coil spring on the driver side has settled more than the others. Your shock doesn't carry the weight of the vehicle, it merely helps control movement of the axle
cosmiccharlie
Aug 12, 2020 01:42 PM
freshdew82
Nov 7, 2012 10:07 PM
sarahgibbons5
Jan 18, 2010 11:44 AM
mherson
Aug 25, 2009 02:20 PM
bennycisco
Jan 15, 2007 07:45 PM
