Rear Jump Seat Bracket
I'm removing the jump seats, and I would like to remove the mounting brackets as well. I have the rear air, so I have the cage mount on the driver's side. All bolts out except for one tricky one. It looks like it has a spot weld on the bolt, as it turns with the entire bracket.
Any ideas on how to get this out? It's a tight spot and will be difficult to cut. I've seen these brackets out with the jump seats on eBay quite a few times, so I was surprised to find a weld on the bolt. Tried to take pics but hard to get focus.
Well, I feel like an idiot. Yes, the bolt is welded to the cage mount. But, after pulling and tugging, it dawned on me that maybe there's a nut on the other side. Sure enough, there's a nut in the wheel well. Spun right off and out came the bracket.
Didn't see anything in the RAVE about this bracket, so for anyone doing the same, hope I saved you some trouble.
Those Torx screws are in there! The left side was easier than the right. For the right, I needed to use a 1/4" combo wrench with a Torx bit taped in it to get to two of the mount screws.
meltdowndave
Audio/Visual Electronics
May 24, 2008 01:40 PM
