rear main seal on discovery leaking
Old Sep 1, 2014 | 06:31 PM
pawright's Avatar
so here is the big question with low compression do you go the extra and replace rings or would re seating valves be enough?
i will have more information to help make this decision when i take the motor out and remove the sump later this week
Old Sep 1, 2014 | 06:35 PM
pawright's Avatar
petrol is gasoline lpg is like propane so burns hotter therefore burning valves quicker but keeps the oil cleaner making rings last longer
Old Sep 1, 2014 | 06:47 PM
TOM R's Avatar
if I had it to do over I would have done rings on mine when the heads were off for head gaskets, esp. since I had the oil pan off too or better would have swapped in 4.6 crank and rods
Old Sep 1, 2014 | 06:51 PM
pawright's Avatar
at only 135,000 miles would it be necessary? but then i cannot say whether it is the original motor the info i can find indicates it is a range rover motor but they may have just put them in both
Old Sep 2, 2014 | 08:12 AM
drowssap's Avatar
on the side of the block should be a spot with the motor number and compression ratio
Old Sep 2, 2014 | 08:15 AM
pawright's Avatar
yes that is 38D29500B which indicates range rover yet it is a discovery but they may have put the same engines in both. ratio is 13:1
Old Sep 2, 2014 | 10:02 AM
drowssap's Avatar
i "believe" Range rovers have a higher compression ratio than discoverys. and it would be no way near 13-1.
it would be in the area of 9.25-9.50.
Old Sep 2, 2014 | 04:43 PM
pawright's Avatar
some web listings that i have seen list that engine number as range rover/discovery so maybe that they put the same engines in both
Old Sep 3, 2014 | 07:02 PM
pawright's Avatar
after removing some of the components off the front of the motor i have discovered that there is quite a bit of oil on the front which is not likely to have been caused by the rear main seal any suggestions?
Old Sep 3, 2014 | 09:48 PM
TOM R's Avatar
My 98 leaked from
Valley pan under intake
Oil relief valve on oil filter adapter,
oil pan,
rear main,
oil lines
Think the only thing that didn't leak was the timing cover and front main
