Rear shock mounts
Rear shock mounts
I lifted my truck over the weekend, broke an upper rear shock mount in the process. I did manage to salvage it enough to be usable, but I want to replace it asap.
In looking online, I'm seeing aftermarket mounts that mount the top eyelet higher or lower than stock. What are the pros and cons to changing the top mount position? Is this something I should do?
I installed 2" RTE springs, +50mm Terrafirma shocks. I would like to get as much travel out of the suspension as possible.
If you put lowered shock mounts, and you've got longer shocks, you might bottom out the shocks when you stuff the tire into the wheel well. You might need longer bump stops. When I put the rear axle in my d90 this weekend, I pulled the springs and the shocks and sat the rear on the bump stops to see about how much room I've got for shocks.
Lowered upper mounts let you run stock(or just slightly longer) length shocks with a lift.
Raised upper mounts let you run longer shocks with a lift. A longer shock will have a longer compressed length. This could be problematic with certain lifts with the shock mounted in the stock location. By raising the mount you effectively lengthen the upstoke.
I would say you should get a stock mount and use that(if you even need to replace it). Run your setup for a while and figure out where you want to tweak it.
FWIW I run 11.25" travel Rancho shocks and use the stock upper mounts on my 3" RTE lift. Check my avatar to see my articulation. Once you go above 2" or really wanting articulation, you need to pull out the tape measure and start pencil whipping the numbers.
CUpgt
09-01-2013 01:23 PM
fishEH
08-16-2012 05:20 PM
turf63
05-04-2012 09:15 AM
