Rear shock mounts
Old Apr 29, 2013 | 11:32 AM
Yeti's Avatar
Default Rear shock mounts
I lifted my truck over the weekend, broke an upper rear shock mount in the process. I did manage to salvage it enough to be usable, but I want to replace it asap.
In looking online, I'm seeing aftermarket mounts that mount the top eyelet higher or lower than stock. What are the pros and cons to changing the top mount position? Is this something I should do?
I installed 2" RTE springs, +50mm Terrafirma shocks. I would like to get as much travel out of the suspension as possible.
Old Apr 29, 2013 | 12:15 PM
jafir's Avatar
If you put lowered shock mounts, and you've got longer shocks, you might bottom out the shocks when you stuff the tire into the wheel well. You might need longer bump stops. When I put the rear axle in my d90 this weekend, I pulled the springs and the shocks and sat the rear on the bump stops to see about how much room I've got for shocks.
Old Apr 29, 2013 | 12:19 PM
fishEH's Avatar
Hit up Paul Grant or somebody for a good used upper mount. I too sheared off the end of the bolt when I installed my first set of shocks. Fortunately there was enough stud to work with and its been fine for 3 years now.
Lowered upper mounts let you run stock(or just slightly longer) length shocks with a lift.
Raised upper mounts let you run longer shocks with a lift. A longer shock will have a longer compressed length. This could be problematic with certain lifts with the shock mounted in the stock location. By raising the mount you effectively lengthen the upstoke.
I would say you should get a stock mount and use that(if you even need to replace it). Run your setup for a while and figure out where you want to tweak it.
FWIW I run 11.25" travel Rancho shocks and use the stock upper mounts on my 3" RTE lift. Check my avatar to see my articulation. Once you go above 2" or really wanting articulation, you need to pull out the tape measure and start pencil whipping the numbers.
Old Apr 29, 2013 | 12:25 PM
jafir's Avatar
Yeah, I only measured it because it was free to do at the time
Old Apr 29, 2013 | 09:36 PM
Yeti's Avatar
Thanks for the feedback. I will look for a used mount.
Old Apr 30, 2013 | 07:06 AM
Yeti, so you have brake and suspension issues, what have you done wrong to **** off the Rover Gods?
Paul number is in my signature section if you need it.
Old Apr 30, 2013 | 05:50 PM
Yeti's Avatar
Mike, I tried to make my truck happy, fixing stuff that leaked and lifting it so the tires did not rub. My truck must not have been happy about it
CUpgt
Sep 1, 2013 01:23 PM
fishEH
Aug 16, 2012 05:20 PM
twr7cx
Jul 4, 2012 07:52 PM
turf63
May 4, 2012 09:15 AM
ValveCoverGasket
Dec 17, 2011 04:34 PM
