rear tail light covers
Old Apr 30, 2020 | 05:25 PM
chandlerhayes01's Avatar
Default rear tail light covers
I found some read tail light covers that i wanted to mount on the d1. I ordered them from and individual and when they arrived they did not have mounting hardware. So my question is where do you find mounting hardware for these? I have search and came up empty.
Old Apr 30, 2020 | 05:54 PM
OverRover's Avatar
It depends on the style of the lamp guard.
If you have what's in the pic below those guards are # RTC9503AA and the hardware kit is #RTC9503K.
If that's what you have then give L8 a call any they should be able to get just the mounting kit.
I know it can be had > https://www.britishpartsofutah.com/D...p/rtc9503k.htm
BUT I would still call L8 first!
Here is the complete assembly/kit > https://lucky8llc.com/collections/di...ht-guards-pair
Old Apr 30, 2020 | 06:04 PM
i have those. Talked to lucky8 and they do not sell the hardware kit.
Old Apr 30, 2020 | 06:06 PM
sucks that the damn hardware cost almost as much as the light guards themselves
Old Apr 30, 2020 | 06:22 PM
OverRover's Avatar
No doubt $82 is way spendy for B$!
Now that you have the mounting kit part number I would see if RN, AB, or Trevor @ RovahFarm would order it for you.
If not it's time to order from across The Pond. Search the part number there are UK options.
For example, Rimmer Bros lists the guards (not that you need those) and the mounts for $60 +S US. I'd bet they will have the kit too.
> https://rimmerbros.com/Item--i-RTC9503AABP
Old Apr 30, 2020 | 06:42 PM
i sent rimmerbros an email inquiring about it
Old Apr 30, 2020 | 07:24 PM
OverRover's Avatar
OK....NOW I have it figured out!
The RTC9503 (K) part number is BS from the BPU site that they "made up". Tricky bastard$
The Lamp Guard Kit Part number is correct at RTC9503AA
>>>> The Mounting Kit (LR calls it a fixing or repair kit) is STC8048 <<<<
Searching that number gives much more promising results.
RN looks like they can order it for $73.11(plus 10% off). > https://www.roversnorth.com/parts/st...it_rear_guards
Even the Online Dealer Sites in the US show this as a live number for less $. > https://parts.landroverhiltonhead.co...repair-stc8048
And again this part number is available at many shops in The UK.
That's all I got!
heews
Jan 3, 2020 02:24 AM
fishEH
Oct 22, 2011 04:57 PM
Wilky1978
Mar 12, 2010 07:04 PM
fluffdaddy
Mar 29, 2008 06:24 PM
zracin
Feb 18, 2008 10:24 AM
