rear window ecu bypass
Old May 5, 2015 | 01:09 PM
elric699669's Avatar
4th Gear
Default rear window ecu bypass
Hello New to the forums but trying get this figured out. I am trying to get my rear windows to work again i'm following the directions on the AB website but can't seem to find the green and white wire to tap into. Anybody that may have done this could you lead me in the right direction I've got a 1996 Discovery 1
thanks
Old May 5, 2015 | 01:16 PM
USNAVYORDNANCE's Avatar
Pretty simple man. There's a step by step write up. I have pictures on one of my threads on how the window eco should look once bypassed.
Old May 5, 2015 | 01:55 PM
4th Gear
Default found it
ok so i found it now my front windows won't roll up and down. they worked before? Is that normal i may just take the ecu out and try the repair that way.
Old May 5, 2015 | 09:50 PM
vegas99d1's Avatar
here is something i wrote up awhile ago about the window lift ECU:
Repairing the Window Lift ECU - How To
Old May 6, 2015 | 12:29 PM
4th Gear
Ok so got the ecu out repaired the cold solder joints and still only getting one of my rear windows to work. Now i may have another issue with the other window but the fact that both my front windows quit working is whats bothering me now. I can hear the relay's on the ecu clicking when i press the switch but the motors don't run. Any ideas for this?
Old May 6, 2015 | 01:21 PM
FLA Rover's Avatar
heres the vid I used to fix mine.
Old May 7, 2015 | 06:34 AM
vegas99d1's Avatar
Wow, that guy used my walk-thru pics in the video and didn't even credit me! The struggle is real!
Old May 12, 2015 | 07:14 AM
4th Gear
so that was my fault blew a fuse trying the bypass 1 of the back windows still isn't working but could be a bad switch. I will keep checking.
Old May 12, 2015 | 09:12 AM
jimvw57's Avatar
I replaced the switches on the console between the seats as mine would work sometimes... I took the old ones apart and cleaned the contact s inside, now they work great! No hidden springs that jump out when you open them up, easily taken apart, cleaned and re-assembled.
Old Aug 6, 2015 | 03:36 PM
AL518's Avatar
Hey Guys,
What's the next step if all this doesn't work?? I've checked the ecu board, which looked good. Soldered up the usual point anyway = no change. Switched the front/rear switches in the center console and that's not it. Tried the AB wire bypass, only not sure into which side of the plug to connect, I did the side closer to the engine bay instead of what seems to run up and to the radio area = no good. Fuses are good too.
BTW, mine is a 95 RRC. I can only see one difference in my ECU circuit board from the Disco - on all the images I can find on other write ups the board is labelled RY2E, mine is RY2D and looks slightly different; the jumper wire that everyone has put in spans a different set of solders on mine.
Pics are in the next post!
Any ideas are greatly appreciated.
