Rear Window ECU Problems?
Old Oct 26, 2018 | 05:50 PM
ihscouts's Avatar
Originally Posted by whiskeynipple0088
not sure if you've tried but to resolver is really easy - you can unbolt the two nuts at the front of the ECU and swing the whole thing down (you have to remove one other bolt that holds a bracket below) for better access - and pop the front off and slide the board out - took me all of 15 minutes once I realized to release the 2 nuts
It is a super easy repair and I was quite amazed that is was something so basic as poor soldering. It was a production problem that lasted throughout the D1 model manufacturing and I'd guess there isn't one in a junkyard that doesn't need the same attention to detail.
Old Oct 30, 2018 | 11:21 PM
rickroverover's Avatar
My 2 bits -- try the window without the card slid into the slot.. just connected and hanging in a SAFE - non metallic way. I had one case of a card that would work until it was slid all the way in. I assume there was another weak spot that I could not find and when slid in, it was putting pressure on the right spot to prevent it from working. I ended up leaving it about an inch out of the holder.
Old Oct 31, 2018 | 11:07 AM
jimvw57's Avatar
right around the 6 min mark he shows the bad solder joint.
Old Oct 31, 2018 | 03:11 PM
jerichards93's Avatar
Thanks for the guidance! I ended up jumping around the ECU like its described in the Atlantic British instructions, however, I used my own wires and connectors. Thought paying $20 for that was a little unnecessary and I didn't want to wait on shipping. The job was very simple once figured out the problem.
Once I finished wiring it and gave it a try.... you all prolly already know what happened... rolled it down once and the little plastic circle son off a B broke... LOL!
Old Oct 31, 2018 | 05:17 PM
Originally Posted by jimvw57
https://www.youtube.com/watch?v=kt6odNB3c8s
I found this video a while ago and was impressed how well he was working on this project - I know how hard that card is to get out without lowering that enclosure. Skill and persistence.
Wildrider
Mar 14, 2017 08:28 AM
Iandrover
May 5, 2013 05:15 PM
mlink
Jul 25, 2012 05:38 PM
wheelgarage
Sep 15, 2011 04:22 AM
Spencerfitch
May 28, 2010 06:34 PM
