Refinishing Your Rear Bumper
Old Sep 25, 2012 | 05:49 PM
Rover_Mike's Avatar
Post Refinishing Your Rear Bumper
I'm sure there are many people like me who have a rusted and/or dented bumper so I thought I would share the simple process of bringing back the luster of your rear bumper. Note that if the rust is too bad or it is really dented you will need a replacement.
Tools and Supplies
1. Socket Set to Remove Old Bumper
2. Xylene or Xylol
3. 150 grit Sandpaper
4. 600 grit sand paper
5. Self-Etching Primer
6. Chassis Paint w/primer (your choice of color)
7. Clear Coat (for gloss and seal)
8. Plastic Adhesion Paint
9. Cheap microfiber rags that can be thrown away
Directions
1. Obtain a replacement bumper from your local salvage yard. I got mine for 30.00 and it came with the end caps and lights (it was a lucky find)
2. First prep the new bumper by coating the rags with xylene and rubbing until the black outer coating is gone and you will be left with a greenish primer. This will take about 45min.
3. Now begin to sand down the surface to bare metal so that you find all of the rust spots. This will take about 1 hour.
4. Now sand down the rust spots until the rust is no longer visible. I used a dremel for the really difficult parts. This will take about 30min.
5. Again take the Xylene and really clean and prep the surface to remove all dust and dirt. (do not use water since you just removed all of the rust)
6. With in 30min of sanding lay down the primer (follow the directions on the can). Timing is very important because if you leave it out with bare metal the rust will return.
7. Next lay down 2-3 coats of the Chassis paint with in 35-40 min for best adhesion.
8. Lastly lay down final clear coat and let bumper set over night.
9. End caps should now be lightly sanded with 600 grit sandpaper and cleaned thoroughly.
10. Using a good plastic adhesion paint do 2-3 coats and let sit at least overnight if not 24 hours.
11. Lastly Remove and install bumper by reading the Rave Manual or watch this youTube video:
Here it is installed:
I hope this was helpful, if you have any questions PM me.
Old Sep 26, 2012 | 11:04 PM
georgep's Avatar
Thanks for the HOW TO they are always great.
Old Sep 26, 2012 | 11:41 PM
Rover_Mike's Avatar
I was going to do a write up on rhino lining the whole truck but wasn't sure if anyone would actually want that tutorial. Hahaha
Old Sep 27, 2012 | 12:01 PM
slanginsanjuan's Avatar
no but i want to see more of it.
Old Sep 27, 2012 | 12:40 PM
Rover_Mike's Avatar
ill throw some pictures together this weekend
Old Sep 27, 2012 | 01:38 PM
honda50r's Avatar
Good write up! Sticky this mods?
Old Sep 28, 2012 | 08:45 AM
DiscoJag's Avatar
Geat write-up, thanks ! I need to do this. Everything that's steel on my truck has begun to rust. The stock running boards went by the boards first. They rusted out right under the rubber coating. Fortunately, most of the body is aluminum, otherwise I'd be in deep doo-doo.
Old Oct 1, 2012 | 02:44 PM
Rover_Mike's Avatar
yea fixing the rust was the most time consuming, i did the roof and it took so long.
bcolins
Jun 22, 2013 08:55 PM
s928s
Nov 11, 2010 05:15 AM
DiscoWest
Sep 23, 2009 10:15 AM
Zonk872
Appearance & Camping Set Ups
May 1, 2007 10:26 AM
