Removed radiator and OMG.. DIIRRRTTTYY
I reccomend to EVERYONE out there. remove your radiator next time your doing a coolant change and clean inbetween the two. It appears the bugs like to go around the first one and sit in the space between the two. I must have found 25 million dragonflys in between.
This is exactly why I try and remember to tell people to wash the radiator with a hose at least once a year, even just running the hose down there will wash most leaves, pine needles, pollen, bugs etc out.
It does make you wonder if there shouldnt be an opening at the bottom as a "clean out"
I spent close to a hour with compressed air and a hose getting mine cleaned out last year. Incredible how much crap gets in there. I am going to check mine out again just to be sure it is still clean. been about a year.
