replace radio head unit
Old Nov 15, 2015 | 03:10 PM
marmarrok's Avatar
Default replace radio head unit
Planning on upgrading my head unit in my land rover discovery from the classic one to a touch screen with features including bluetooth and navigation, however I hardly know anything about the process and where to look. I stopped at Best Buy where I was informed that they don't do installation in land rovers. Now, I am looking for any OEM head units that are compatible with a discovery without having to cut into anything due to the fact that I will most likely have a friend of mine complete the installation. Any suggestions on where to find an OEM head unit that will fit?
Old Nov 15, 2015 | 08:30 PM
TOM R's Avatar
I think the radios a standard size, iirc you need to run new speaker wires to wire around the amps, do a search here I know there's good threads on changing the radio
Old Nov 17, 2015 | 08:22 AM
drowssap's Avatar
I would suggest looking at crutchfield. You dont have buy there but they will tell you what fits and what adptors you my need to make it plug and play
Old Nov 17, 2015 | 03:57 PM
Joemamma1954's Avatar
Any single-din aftermarket should work. Depending on what system you have, will dictate what harnesses you would need for proper integration. For example, if you have diversity antenna, OEM amplifier, etc. As drowsapp said, go to crutchfield and check out head units, then see what xtras you need, then shop around for best prices on components. I kept all oem wiring, amps, speakers and install was easy. I added sub and mono-bloc amp, and replaced the two blown speakers in rear hatch door. Sound is better than I had expected(originally planned all speaker replacement).
Kevintj1
Mar 31, 2013 04:01 PM
Derry Quinn
Freelander
Sep 5, 2012 02:17 AM
Timpala`
Aug 4, 2009 09:38 PM
SantaCruzRoverGirl
Jan 20, 2009 02:49 PM
bmkraus
May 4, 2008 09:11 AM
