Freelander Talk about the Land Rover Freelander within.
Need to replace ABS Unit?
Old Sep 4, 2012 | 06:24 AM
Derry Quinn's Avatar
Default Need to replace ABS Unit?
I’m totally ignorant of electrical diagnosis and would welcome some advice please.
I have an ’07 Freelander 2, with 70k miles on clock .Two warning lights (ABS & HDC) have appeared and the cruise control does not work. I've tried HDC and it does not work; on braking hard the ABS 'whine' cuts in but I cannot hear the 'ticking' ...
The Garage says they ran a diagnostic test and the answer is 'fault code C0044-28 brake pressure sensor new ABS hydraulic unit required'.
How accurate is the diagnostic procedure? (Does it run through ‘what if’ scenarios/steps?) There seems to be a lot on the web about faulty sensors, etc, (‘three amigos’) so is it possible that this is just a sensor/relay/fuse?
A new ABS hydr. unit is very expensive so I want to make sure this is what is needed before I commit...
Thanks in advance.
D.
Old Sep 4, 2012 | 03:32 PM
Rovin4life's Avatar
I believe I had that originally when a vehicle was new a vehicle had no brake lights as well. It turns out it was the internals on the abs module. The sensor is inside the module.
Old Sep 5, 2012 | 02:17 AM
Thanks Rovin'.
I expect that is why the entire unit must be replaced?
elboy0712
Dec 19, 2010 02:48 PM
SantaCruzRoverGirl
Jan 20, 2009 02:49 PM
bmkraus
May 4, 2008 09:11 AM
Phototone
Apr 8, 2008 03:46 PM
