Replacement fuel pump issues. Please help!
Old Apr 13, 2012 | 06:36 PM
gulfcoastgorilla's Avatar
Default Replacement fuel pump issues. Please help!
I received a fuel pump from autopartswarehouse.com. They swear it's the same pump. But my old fuel pump has 2 electical plugs. This new fuel pump only has one electrical plug to fit into. What does the second plug do and will it still work. Everything else fits besides the new fuel pump has 1 plug and my disco 1 has two plugs to plug into it
Old Apr 13, 2012 | 06:41 PM
Higgs Boson's Avatar
No good. Your truck has AEL(advanced evap loss). The other plug is for a pressure sensor IIRC.
Old Apr 13, 2012 | 06:46 PM
So what do I do?
Old Apr 13, 2012 | 07:15 PM
What would happen if I just left the second plug unplugged?
Old Apr 13, 2012 | 08:07 PM
Danny Lee 97 Disco's Avatar
I think you would have major issues. Your emissions system would not function properly.
That is why I avoid places that do not have the proper knowledge about Land Rover Parts. LR made many mid stream changes. My 97 is pre_AEL and only has the one plug, later in the same year they totally changed and those are not interchangable. Look at the identification plate under your hood for the emissions data, Regular or Advanced.
Old Apr 13, 2012 | 09:11 PM
Do they make an adapter since the fuel pump is the same. Make one plug adapt into being two plug?
Old Apr 13, 2012 | 10:27 PM
You need to return that pump and buy the correct one.
Old Apr 14, 2012 | 01:14 AM
You know any website with one under 300 dollars. I payed 118.00 for the one without the two plugs at autopartswarehouse.con
Old Apr 14, 2012 | 10:36 AM
RobertBrowning's Avatar
i am looking for a (i guess) single plug fuel pump 4 my 97 disco...
https://landroverforums.com/forum/di...e2/#post313142
put pictues there.. did u get whole assembly 4 118 or just pump? can you send me link? thx...
Old Apr 14, 2012 | 11:46 AM
fishEH's Avatar
What exactly is wrong with your old pump? If the housing, float, connectors, etc are in good shape you can reuse them and just swap the pump for a late 80's Chevy pump. Just the pump will run $50-100 for just about any auto parts store. Search, there's lots of info on this method.
