Replacing Camshaft
Old 04-11-2012, 10:31 AM
slanginsanjuan's Avatar
Did you start? You haven't shown any pics of the new parts..just the boxes. Or did I miss that.
  #22
Old 04-11-2012, 04:28 PM
ColoDisco's Avatar
Sure did. And for the last 2 ****ing hours I have been trying to remove the stupid cooling fan. I put this thing on and it still will not come loose. If I remember correctly it is reverse thread correct?
  #23
Old 04-11-2012, 04:45 PM
Higgs Boson's Avatar
Put a large adjustable on the fan clutch so it's sticking straight up. Put a 1/2" breaker bar in the belt tensioner hole and push the bar to ADD tension to the belt. Smack the adjustable toward the passenger side sharply. This should break it free pretty easy.
  #24
Old 04-11-2012, 04:46 PM
ColoDisco's Avatar
Per rave:
"NOTE: Nut securing viscous unit to pulley has a left hand thread. Release by turning clockwise when viewed from front of viscous unit."
  #25
Jake1996D1's Avatar
lol no!!!! lefty loosey righty tighty!!! You have been tightening it for two hours
  #26
Old 04-11-2012, 04:47 PM
ColoDisco's Avatar
Per rave:
  #27
Old 04-11-2012, 04:50 PM
adigerol77's Avatar
32mm (I believe) and smack it with a hammer quickly to the pass side or, I believe AZ has the FC tool to hold the fan and keep it from moving. Another trick is an air hammer and long chisel blade in it, place it close to the edge of the nut and pull the trigger quickly. If I remember it's lefty but I've got a 50/50 shot at being right on that. I did all that crap a year ago, and it's been a long year.
  #28
Old 04-11-2012, 05:25 PM
ColoDisco's Avatar
Per rave:
  #29
ColoDisco's Avatar
Per rave:
  #30
Old 04-11-2012, 05:26 PM
ColoDisco's Avatar
This forum is freaking out. I did not triple post that. So which way is it?
Quick Reply: Replacing Camshaft
