RH Front Window won't work - Motor, regulator and Switch all Good
I've been trying to get my RH front window working. Regulator is fine, Switch is fine (I plugged LH front window wiring harness to the switch and it works). Rover's North told me it was certainly the motor so I bought one. Replaced the motor and it still doesn't work!
When I actuate the switch I can hear a slight "clicking" sound behind the glove box so it seems that something electrical is happening when I actuate the switch.
Not sure where to go from here - already wasted the $$ on a new motor.
Love to hear any suggestions. Thanks!
thanks for the reply. can anyone provide me a little more detailed description of the ECU so I can identify it? I pulled the glove box out several weeks ago to try and determine where the clicking sound was coming from (I'm guessing the ECU?) but I couldn't make sense of all the wiring and electrical components there. Maybe a photo?
Thanks so much!
Thanks so much!
OK, I found a thread with some pictures so I think I can get it out pretty easily.
However, I've read here in other posts that the ECU only controls the rear windows and there is a simpler relay controlling the fronts.
Can someone confirm or deny this? If it's true, can someone direct me to the proper relay that may be bad for the front windows?
Thanks y'all!
Thanks y'all!
Al Blue4.6l
08-14-2011 05:28 PM
phillman98
12-04-2010 10:01 PM
VikingDiesel
03-08-2009 09:53 PM
bcolins
10-20-2008 10:52 PM
