Rough Idle at start
Old Aug 10, 2010 | 02:32 PM
bonzadesign's Avatar
Default Rough Idle at start
96 disco 150K
Have been having an intermitent problem with a rough idle following start up. No problem starting but just after. It will stumble and sputter and I can manage to rev it out.
I have changed plugs and leads. The problem is mostly when hot but not always. I disconnected the fuel temp sensor and problem was still the same.
I have removed the fuel rail valve and placed a clear hose on the stem to measure fuel volume. When energised the pump will run for several seconds and produce about8oz of fuel then i can hear the relay disconnect. I ran it several times.
can anyone tell me if this is normal for the pump to run only that long. Obviously there is no back pressure on the pump so i thought that might be a problem.
No fault codes other than O2 sensor but i've put up with those for 50K.
Any help appreciated
Adrian
Old Aug 10, 2010 | 05:33 PM
#1 suspect is the fuel temp sensor.
Next would be a dirty intake, idle control valve or cheap gas.
Old Aug 10, 2010 | 09:07 PM
Cosmic88's Avatar
your fuel pump operates solely based on flow and resistive pressure. If the flow is blocked it will pump slowly, producing less volume in a given time and will take longer to reach its set cutoff pressure... once the pump has reached its set pressure in a closed system (ie. ignition on, engine stopped). You should have about 30 psi at the rail. and it shouldn't cutoff with your measurement test (open system).
If your system exceeds that 30 psi the fuel pressure regulator returns the exces fuel to the tank. When you disconnect the FTS you mimick a nonworking sensor... my guess is that you would not see a difference.
I'm votin for either the FTS or the Idle air control valve since this problem only happens at initial idle... and based on your mini tuneup.
Old Aug 11, 2010 | 05:45 AM
Thanks for the input.
Just to cover the fuel pump...do you think there is a problem with the pump if it will not run continuously without shutting off in an open system?
Is there a way to test the idle air control valve and the FTS?
Thanks again.
Adrian
96 Disco 150K
Old Aug 11, 2010 | 09:32 PM
The fuel pump will only run for a few seconds unless the engine is running.
This is normal.
Old Aug 12, 2010 | 01:56 PM
lamont778's Avatar
Hey bonzadesign, did you figure this one out? I am having a very similar issue with my 98 disco 1. The only difference is it seems to idle more roughly if I'm parked on an incline with the front going up-hill.
dillhole
Feb 20, 2020 02:30 PM
DiscoIIBrandon
Jul 10, 2018 07:47 PM
KGN96discoSE7
Sep 23, 2017 07:23 AM
ripio31
Freelander
Sep 8, 2013 04:06 PM
DISCO1995
Nov 20, 2011 01:33 PM
