Rough ride. Sometimes
Old Jun 20, 2014 | 01:25 PM
jbb611's Avatar
Default Rough ride. Sometimes
Any logical reason my 97 discovey will have drastically different ride characteristics from one day to the next? New shocks and struts ome medium duty. Lots of new bushings, not all. All fittings at correct torque. Some days the truck seems to absorb the road and ride nice and others it seems to shake with with every minor road defect. Same roads everyday.
Old Jun 23, 2014 | 09:28 PM
jbb611's Avatar
Could it be related to sloppy transmission that occasionally shifts erretically? Electrical signals miscommunicating?
Anyone?
Old Jun 23, 2014 | 10:27 PM
TOM R's Avatar
You done u joints?
Old Jun 24, 2014 | 09:49 PM
jbb611's Avatar
Originally Posted by TOM R
You done u joints?
Tom. Great idea. Way overdue as in never done. Ill start there. Needs it anyway so it cant hurt. Seems to be more play than there should be when twisting transaxle by hand. Thanks.
Old Jun 27, 2014 | 11:33 AM
jbb611's Avatar
Update. Haven't replaced u joints yet, but yesterday the truck rode like a dream.
Question: how does wheel speed/ speed sensor talk to transmission.
The problem "feels" like there is no suspension at all. As if the wheels don't know they are slowing down or speeding when hitting bumps and not absorbing them. I really don't understand the finer points of the electronics and what they do to help the ride, if any.
Old Jun 27, 2014 | 04:35 PM
TOM R's Avatar
What your saying makes no sense
Wheel sensors go to abs ecu
Transmission feeds speedo
If you have HD springs and no extra weight it can ride bad, if you lifted and left sway bars on it can ride bad
After u joints adjust swivel pre load these 2 items can drasticly effect drivability
Old Jun 28, 2014 | 09:55 AM
jbb611's Avatar
Haha. I know it doesn't make sense. If it made sense i wouldn't be looking for input.
I guess i need to get codes read. Abs acts up occasionally and may also be part of the issue. I just don't know. Is there a decent reader i can pick up and work myself or is it better to take it to a shop.
I apologize for not knowing more about these systems. But again thats why i thought to ask you guys.
As for my MEDIUM DUTY suspension, i do carry more weight than stock 100% of the time. Front and rear. And the question at hand was happening before i replaced shocks/springs. So this issue is not related, i don't believe. Lift is minimal. Sways are still on, but thats the thing...ride is Great sometimes. Its not a constant bad ride. Im leaning towards electrical. Thinking out loud. Ill study the systems this weekend so i know wtf I'm talking about.
Ill probably bite the bullet and take it to dealer. I cant find any good indy shops around here. Thanks for trying.
Old Jun 28, 2014 | 04:11 PM
TOM R's Avatar
dealer will just rake you over the coals, vehicle is too old for them to know what to do esp if you modified it they will just take your money
if abs is acting up open the fuse box under hood and pull the abs pump fuse with a Phillips head, even working right it is nfg, I tried adjusting the sensors and such to no avail and it sucks when you hit the breaks and it kicks on for no reason and the car will not stop unless you let off and hit brake again fast
if you did shocks springs and all bushings, swivel preload, u joints, there is also the trans and motor mounts, can be bad but look fine, took out my trans and rolled it on the side and 1 mount fell apart but looked fine so...
it is hard to say over the web what is normal and what is a problem heck could be a bad belt in a tire
Old Jun 29, 2014 | 11:13 AM
95RRCLWB's Avatar
Possible bad swaybar links. Mine rode bad and after I took off the swaybars, it was a totally different truck. My swaybar links were a bit seized so I prevented suspension movement.
Old Jun 30, 2014 | 08:23 AM
TOM R's Avatar
Mine rode bad after lift handled bad too till I removed the sways, the rear one the links became inverted and jam bed the bar to the rear stopping the suspension from working right
