Rough start to over rev to dying
Today took the rover to a short off road section on a farm before work with some buddys. Parked the rover in the lot at work like normal, when i go to leave and start her up, she starts really rough, turning and turning. All the while im hearing a clicking from the passenger side of the car. When it finally starts it revs up to about 3k, then starts slowly dropping down to idle, and then dies. On the third or fourth attempt it fires up and seems to ilde just fine It was kinda low on fuel, just below a 1/4 tank. I limped it to a gas station and filled it up and it ran fine.
I have some theories, but i would like to hear a consensus and your ideas, thoughts, advice? Yay for the mass pooling of information that is a forum.
I just gave it a tune up last week, new plugs, wire, trans flush and filter change, oil and filter change, coolant change. Nothing out of the ordinary all the colors and smells of fluid one could expect.
If you were bumping around with a low tank, you could have been starving your pump. It uses fuel to cool its self. Getting a full tank seems to have changed things? I would watch the pump for now. The next time it won't fire, just turn the key on for 10 seconds and off 3 timed before trying to start. Do not hit the gas pedal while doing it. See if it makes a difference.
After i worked on it today ive ruled out this stuff
fuel pump; i pulled its control fuse and it makes the same attempt to start
fuel injectors, same thing as the fuel pump as well i pulled one and turned the engine over and it shot fuel
all fuses
neutral start safety switch; put trans in neutral to get the same outcome
Like i said the only code im getting is the p1447, can a purge valve cause it to not start?
all fuses
As for the purge vale it wont make the engine run rough,I had the 1447 code last week and found 1 at ebay for 10 bucks and bought it the person was good on there price's and shipped quick, order monday nite got it wed afternoon,that fixed the code. On the rough running I had a trarus giving rough ideal and I pulled the MAF plug and it ran fine so I replaced it and its fine, do you have reader that you could look at the pid's, I am using a ford factory reader NGS which lets you see all the sensors it could be an injector or the harness.Sorry but without some high dollar reader it's a hit and miss,you might buy a Noid at Az to check the injector harness,the injector can cause some roughness if its pluged,check out youtube for how to clean injector's there's some great video's on it.
