Rover won't crank and alarm keeps going off
sorry posted under the wrong one first. my drivers door won't unlock bc it's broken. it will only lock. I then unlocked from the passenger side then unlocked the drivers door from inside. now it won't start and the alarm goes off every time I try to turn the engine over.
Sit in the drivers seat and close all doors, push down on the drivers door lock and lock all doors.
Wait a few minutes, then pull up on the drivers door lock to unlock all the doors, then open the drivers door, close drivers door and try to start the truck.
Then do this.
https://landroverforums.com/forum/di...-bypass-46728/
Doesn't make sense. Does the '98 have a key sensor in it that detects metal types? My understanding is that the door locks have a linkage to the actuator. If the key is worn out, it will not turn the tumbler, thereby not unlocking the vehicle and disabling the alarm. Sounds like the tumbler in your drivers door is worn, not the key.
