Rover won't crank and alarm keeps going off
Old Feb 6, 2012 | 05:09 PM
Originally Posted by Marnold-98-Disco
Turns out it was a bad key, the previous owner had new brass keys made for it and real Land Rover keys are from stainless steel. The Brass only last a short time before going bad. The driver's door lock wasn't broken it could just tell the key wasn't authentic.
That has nothing to do with your problem, absolutey nothing.
The truck does not know the difference between a brass key and a steel key.
Old Feb 6, 2012 | 05:24 PM
IMHO your lock cylinder/switch is showing wear, and problem will come back. Please don't put WD 40 in it, it will solvent gunk, then spread it around, and allow it to dry in all of the tiny parts of the lock cylinder. Graphite is much better. If you want home made graphite, scrape the lead in a pencil into a powder and coat the key with it and insert in lock several times.
Old Feb 6, 2012 | 08:19 PM
Silicone spray for all of your locks, latches and key holes.
Old Feb 7, 2012 | 11:55 AM
Marnold-98-Disco's Avatar
The new key locks and unlock the doors. should I still graphite the door?
Old Feb 7, 2012 | 12:13 PM
Chris-bob's Avatar
Yes, just apply graphite to your key and insert it into the lock and turn it, then remove the key. Repeat this process several times adding graphite once again after a few times. Do this to all of your locks. It will help immensely.
Old Feb 7, 2012 | 01:19 PM
just tested the battery, it's bad. hopefully replacing it will solve this problem! any suggestions on the best battery?
Old Feb 7, 2012 | 04:25 PM
replacing the battery didn't work. alarm sounded as soon as I hooked up the new battery. wtf?!?
Old Feb 7, 2012 | 04:39 PM
I saw something about a Immobilization Bypass? and a alarm spider fix? does this have anything to do with my problem?
Old Feb 7, 2012 | 05:07 PM
Chris-bob's Avatar
Start with your locks. When that is done, we can go from there.
Old Feb 7, 2012 | 05:09 PM
ok. I bought a duralast battery (800 cranking amps) from auto zone. I realize this isn't the best battery but I needed to know if my old battery was the reason behind all this (it wasn't). I have a guy telling me that interstate batteries are the best and that is whats MUST be in there. is this true? does it really matter?
