RPM needle going crazy: 96
Old Feb 20, 2017 | 02:07 PM
Courtney Lee Wright's Avatar
Default RPM needle going crazy: 96
Rpm needle going crazy while driving. Rpms not going crazy just the needle.
LR also dies sometimes while starting it. Actual rpms putter down and LR dies. It is worse with the AC on.
It helps if I keep my foot on the gas sometimes.
Old Feb 20, 2017 | 03:58 PM
Best4x4's Avatar
Your tach gets it's signal from the alternator. Check the connection (smaller one) to make sure it's making a good connection.
Old Feb 22, 2017 | 05:52 PM
ROB99DISCOSD's Avatar
​​​​​​​That's good advice right there and damn near certain the cause...
Old Feb 22, 2017 | 06:37 PM
ihscouts's Avatar
It's either the alternator or the wire connector to the dash card.......
Old Feb 24, 2017 | 04:57 AM
D1driver_mgwarrior's Avatar
My 98 D1 would do that. I changed the idle air control valve and it solved my issue
Old Feb 24, 2017 | 07:21 AM
WaltNYC's Avatar
IACV could be the source of the "weak start", but generally it is more persistent than exclusive to start up. For example, mine would stall at the end of an off ramp
Erractic RPMs is likely the connection to the alternator as suggested.
thearmlesswonder
Dec 18, 2014 02:58 PM
XCELLER8
Aug 27, 2009 08:15 AM
KeizerRover
Jun 26, 2009 09:26 PM
wick_60010
Jun 6, 2009 08:35 PM
luxury1
Apr 25, 2009 10:12 AM
