Running Wires For Light Bar On Rack
Old Nov 2, 2015 | 01:47 PM
jpluncford21's Avatar
Default Running Wires For Light Bar On Rack
I'm installing a 32" light bar on my rack and need some help with how to run the writing into the truck. I was thinking through the sunroof, but haven't decided yet. Suggestions? Tips?
Old Nov 3, 2015 | 11:13 AM
MM3846's Avatar
drill a hole through the roof, seal with silicone or black RTV. I've done this on my Disco, and my two XJs. Never had a leak using black RTV.
Old Nov 5, 2015 | 08:27 PM
TOM R's Avatar
Look in my build think there's pics, I ran out the fire wall , through hvac trough then up my snorkel , no hole in roof
Old Nov 6, 2015 | 07:52 AM
Yea I think the previous owner would fly to Tennessee to punch me if I drilled a hole through the roof. I've been looking around at different posts and think I'm just gonna run the writing down the rack and A pillar into the engine bay then back through the firewall. I think I have enough wiring to get that done. I'll update with pictures for future reference
Old Nov 6, 2015 | 12:16 PM
fishEH's Avatar
Here's what I did.
On the drivers side, peel off the weatherstripping around the top of the door frame. I took a dremel and cut a notch in the steel for the wire pass through. Ran the wire and reinstalled the weatherstripping. Continued to run the wire down the A pillar behind the trim and to the switch/relay. No leaks.
Here's how the end product looked.
Old Nov 7, 2015 | 04:59 PM
TOM R's Avatar
Yeah I have been thinking about that for my rear rack lights, I just have a thing about drilling holes in exterior panels for wires so this is a good alternative
Old Nov 7, 2015 | 06:42 PM
fishEH's Avatar
This is thw notch I made. There was a corresponding notch into the non-sealing part of the weatherstripping, but I've since replaced the door seals.
Old Nov 7, 2015 | 08:32 PM
TOM R's Avatar
So does water run in at all?
Old Nov 7, 2015 | 09:51 PM
fishEH's Avatar
Nope.
crumleyjc
Jul 13, 2012 01:57 PM
tigertrakstar1
Mar 10, 2011 04:04 PM
rj95lss
Apr 7, 2010 07:52 PM
dinandan
Jul 4, 2006 10:43 AM
dinandan
Jun 22, 2006 07:22 PM
