Sourcing a Radiator
Old 06-30-2018, 05:29 PM
ajnolin's Avatar
Default Sourcing a Radiator
Looks like my old original radiator finally threw in the towel, and after 20 years has decided to **** transmission fluid all over the place. Does anyone know of a good aftermarket source for a replacement that won’t break the bank? I see a lot of aluminum 4 - core radiators online, with claims that they increase cooling capacity significantly. Does anyone have any experience with these? Any help and advice would be most appreciated, thank you!
Old 06-30-2018, 05:37 PM
Kdo58's Avatar
This the one I bought, I got mine from advance auto and it was even cheaper
https://www.ebay.com/itm/LAND-ROVER-...4383.l4275.c10
Old 06-30-2018, 06:12 PM
vanbadri's Avatar
A Nissens 64029 seems to be the general consensus as the best replacement. Most people will recommend a re-core over replacement, but if it's leaking transmission fluid, it doesn't sound like that's an option... I replaced my original blocked up radiator with a Nissens as the only local shop who would touch it quoted me $200 -over- the price of a new Nissens just to re-core the thing. 64029 is $290 but well worth it IMO. People have had some success with the aluminum 4-core ones but apparently you have to make some modifications to the mounting in order to get it to work. I didn't want to monkey around with any of that so I just swapped them. Unless I'm grossly mistaken, the Nissens is a 3-row aluminum w/ plastic tanks. Some people say they've had plastic-tanked radiators leak in cold weather, some people say they're fine, all depends on who you talk to. I haven't had any trouble with mine, but I live in Florida. What I can say for cooling capacity is that in 80 degree weather, my D1 runs in the 185-190 range, much cooler than what many people say is the expected range of operation. That being said, it does also have a fresh head gasket job and water pump, so there are probably additional factors there.
https://www.rockauto.com/en/moreinfo...316063&jsn=352
https://landroverforums.com/forum/di...adiator-88696/
Cheers mate
Old 07-01-2018, 12:53 PM
whiskeynipple0088's Avatar
Nissens 64029!!!!
i had one of those alum 4 cores - didn’t last a year
Old 07-02-2018, 06:44 AM
WaltNYC's Avatar
$290 at Rock Auto is a good deal for that unit.
Old 09-09-2018, 12:36 PM
ajnolin's Avatar
Ended up with a $50 OE boneyard special, and back on the road after some therapeutic wrenching
vanbadri
02-16-2020 01:53 PM
merebel
02-02-2019 04:57 PM
El Duce
07-22-2016 01:55 PM
Savannah Buzz
01-08-2013 09:41 PM
jwfuller
01-15-2009 08:22 PM
Quick Reply: Sourcing a Radiator
