Scan Gauge Readings off, sensor help
Old Jun 26, 2010 | 09:46 PM
Spencerfitch's Avatar
Default Scan Gauge Readings off, sensor help
Does anyone have any idea as of why my scangauge readings would be off?
There are only a few,
MPG [WAYYY OFF] 1400 MPG..
Horse Power [.5 HP]
And probably one more..
Thought it could be VVS but speedometer reads fine on gauge and dash.
I emailed scangauge and they just sent me another one...
It works on every vehicle but mine.. FIGURES.
Old Jun 27, 2010 | 12:29 PM
batiscan's Avatar
I'm having the same problem. Everything works except fuel consumption numbers. (Haven't checked the HP figures though)
Have you found out what's wrong?
Old Jun 27, 2010 | 01:20 PM
guess its just a Land Rover thing..
Sucks because thats the ONE thing I really wanted it for.
Old Jun 29, 2010 | 10:18 PM
batiscan's Avatar
Unhappy
Talked to their tech support today. The only workaround to get the right correction factor is to use the % correction function. You either keep your finger forever on the button to get 10000% increase or increase the engine size to the max possible, and correct using the % as soon as you have a significant consumption value and redo it again a few times (% x % x %...)
Old Jun 29, 2010 | 11:34 PM
ill try anything
Rover_Hokie
Feb 2, 2014 03:52 PM
GURU06
Jan 18, 2013 01:42 AM
4x4ron
Apr 14, 2012 03:14 PM
Spencerfitch
Jun 16, 2010 05:58 PM
Disco2Fever
Apr 25, 2010 09:12 PM
