SE Disco 98 109K break question
Old Sep 26, 2010 | 03:35 PM
TheIcySea's Avatar
4wd High
Question SE Disco 98 109K break question
When the truck sits for a wile, like overnight, the breaks get mushy. After pumping all is well. During this interval of mushiness when applying the breaks the pedal can get close to the end of its travail. Sometimes it sounds and feels as if the front left (US) sensor/exciter ring are making contact. Given the information I've been able to dig up here, the mushiness may be a master cylinder issue. Using a hand held vacuum pump I bled the breaks replacing about 250ml of dot 4 with no apparent change. Your thoughts please.
TheIcySea
New to me 1998 SE Discovery, 109K, Changed the oil w/15W40, Replaced sub speakers w/DII set from a J-yard
Old Sep 26, 2010 | 04:39 PM
Most likely have a failing master cylinder, that will be the first place to stop.
You will want to do a 2 quart bleed as part of the process.
Old Sep 26, 2010 | 07:15 PM
TheIcySea's Avatar
4wd High
Default SE Disco 98 109K break question: RE
Mike
Thanx for the fast reply. I think your right.
Any suggestions on ware to get the parts. What do you think about the ratcheting sound? Could it be the ball joints making a fuss? Sounds to me to be the ABS ring on the port side front, but I'm just an old sailor, so I'm guessing.
Ben
98 Disco SE. It's red, cool.
Old Sep 26, 2010 | 09:10 PM
kenk's Avatar
If the sound only happens when applying the brakes, I would pull the pads on that side and see if there's crud or something in there making contact.
The best price I could find on a new one was http://www.rovahfarm.com/DiscoIBrakes.htm
adigerol77
Nov 5, 2011 10:53 PM
iceteacy
Feb 10, 2011 07:27 AM
IDAHODISCO
Aug 22, 2008 04:56 PM
sayre05
Apr 16, 2008 09:28 PM
bigugly82
Dec 20, 2006 12:30 PM
