sensor plug repair kit
Old 12-07-2010 | 10:57 PM
DiscoDad's Avatar
Default sensor plug repair kit
Anyone know of a ecu coolant sensor plug repair kit?
Old 12-08-2010 | 10:11 AM
Rebuild it by hand or go to a junk yard cause there is no such kit available.
Old 12-08-2010 | 07:17 PM
What exactly happened?
Old 12-08-2010 | 07:43 PM
DiscoDad's Avatar
Default What happened
Upper radiator hose blew and broke the plastic plug that snaps on the ecu sensor
Old 12-08-2010 | 07:46 PM
Got it.
That sucks.
As long as you can get a good connection with the spade clip and can make sure it wont fall off you dont actually need the plug.
So you might beable to Jerry Rig something.
Old 12-08-2010 | 09:00 PM
Danny Lee 97 Disco's Avatar
I was an Aviation Electrician and a Missile Manufacturing engineer. What you can do after you solder if possible or just crimp on spade connections, you can use what is called a "Potting Compound" to make your own insulating plug.
It is basically a two-part rubber -like material. You could make a small mold of some tape or something and pot it, or you could probably suffice with a good RTV type material. Just make sure the connections are well covered.
Old 12-09-2010 | 07:25 AM
DiscoDad's Avatar
Default Found repair kits!
This may help with future repairs. Connectorsfast.com has a repair kit for land rovers part ev1 can be gotten with plug only or with a
6 inch pigtail for quick repairs. Very reasonable too!!!
Old 12-09-2010 | 08:39 AM
XCELLER8's Avatar
thanks for digging up that site !!!!!!
I was ready to offer you a used one off of an old wiring harness I have , but at those prices you might better have a new one !
Old 12-09-2010 | 07:45 PM
Just added that to the tech section.
Perfect for those who might need a connector in the future.
KlamathMatt
04-17-2020 05:27 AM
univu2
07-28-2012 08:03 PM
primey
10-26-2011 07:24 PM
Disco Alan
04-21-2009 06:22 PM
Quick Reply: sensor plug repair kit
